__Larsson____
So what torque should i use? Mopar Original or ARP spec?
Yessir. And use their supplied lube on the threads and under the bolt head.Lotta folks getting this wrong.... ARP bolts are higher tensile strength than OE bolts, therefore to properly stretch the bolts requires more torque.... Use the ARP spec...
12-pt is also 70 lb/ft but you make an excellent point! Specs may differ for the higher-PSI series!Use the ARP specs, but you need to know which series of bolts you have. The 6 pt is 70#, 12 pt is either 70 or 80 depending on if they are 180,000 or 200,000 psi bolts.
Yeah, sorry I didn't mean it to look like I was barking at ya, the exclamation points were more intended for the OP because it was important info...That's what I said, 12 pt has 70 or 80, depends on which level of bolt 180,00 or 200,000.
Sorry for being overly sensitive.Yeah, sorry I didn't mean it to look like I was barking at ya, the exclamation points were more intended for the OP because it was important info...
