Hi guys, is the torque spec for ARP rod bolts the same as the spec listed in the FSM? 440 RB thanks.
Yes they re-sized and also went to a full-floating pin setup. He's a local HP builder with lots of years and a stellar reputation, buuut I'm just double-checking that everything is torqued good before I button it back up...thanks for the link!I believe it's 50 ft lbs. http://arpinstructions.com/instructions/145-6002.pdf
Did you have the big end resized after installing these?
Thanks Cranky, the set my builder used included the nuts (he gave me the empty packages from all the parts he used...not sure if that's for my own knowledge base or he just likes unloading the trash on the customerI mic my rods to see if they 'need' resizing and if not, I'll stick in the new bolts. If they go in without having to use a lot of pressure, I'll mic them again and 99% of the time, they are still the same. I will also use new nuts for the final assembly. It's the nut that gives up being torqued and it happens after the first time. Not sure anymore if they still do but ARP used to sell nuts separately.....cheap insurance for sure. Rod bolts usually go into the trash after a season of racing or being torqued more than twice.
I was told you can't replace rod bolts and not resize rods. I did it anyway but carefully. Explanation is a bunch of typing.I mic my rods to see if they 'need' resizing and if not, I'll stick in the new bolts. If they go in without having to use a lot of pressure, I'll mic them again and 99% of the time, they are still the same. I will also use new nuts for the final assembly. It's the nut that gives up being torqued and it happens after the first time. Not sure anymore if they still do but ARP used to sell nuts separately.....cheap insurance for sure. Rod bolts usually go into the trash after a season of racing or being torqued more than twice.
Ideally, this is the correct and preferred procedure. I won't say you can't do it without resizing, but I would advise against it.I was told you can't replace rod bolts and not resize rods. I did it anyway but carefully. Explanation is a bunch of typing.
I went with bolt stretch and ended up at 85ft.lbs.I thought ARP went with bolt stretch on rod bolts?
I don't see the problem in double checking their work? Things happen. Just want to be sure something didn't get left a little loose...I'm not taking stuff apart to re-torque it though, for sure. My wrench clicked at 50 on them, that's all I was after, verified to not be loose..You are using an experienced builder. You don't know the correct spec. You How are you going about checking the bolt torque? Unless you take them apart, relube and retorque, leave them alone.
They do but also instruct to torque to 50 lb/ft if you don't have that stretch gauge.I thought ARP went with bolt stretch on rod bolts?
I've heard the same thing for 40 years and quit listening to it around the mid 80's.I was told you can't replace rod bolts and not resize rods. I did it anyway but carefully. Explanation is a bunch of typing.
No corners cut here....but no use in machining something that doesn't need it especially if you have the proper tools to check stuff. No automotive machine shop is going to say that because it's not cost effective for them to spend the time to check stuff and find there's no need to machine a particular part/s. It's a lot faster and more cost effective (there's those words again) to just throw the parts up and machine them. We can talk square decking and align boring next.....
ANY motor I build gets ARP rod bolts and resized. I also highly recommend the customer get it done if they are building it themselves. A little extra money in the beginning will save you lots of heartache when it goes tits up because you cut corners...
Like mentioned above, with the right tools, they can be checked.Ideally, this is the correct and preferred procedure. I won't say you can't do it without resizing, but I would advise against it.
Any machine work I can't do in house WILL be checked once it's back in my hands. There's no such thing as a machinist that doesn't make mistakes. I learned that in the machinist trade and was taught during my apprenticeship to check the work of others and always double check your own work. My last significant engine build came back with .0035 out of round in main bearing bores. And this was from a shop that had experience building Pro Stock engines!! Another high profile shop did a block with .0005 hour glass finish in the cylinders. That doesn't sound like much but it is when the pistons are going in with just .0005 clearance!!I don't see the problem in double checking their work? Things happen. Just want to be sure something didn't get left a little loose...I'm not taking stuff apart to re-torque it though, for sure. My wrench clicked at 50 on them, that's all I was after, verified to not be loose..
