chargervert
That's why I am sure this will happen!Not me. He already has a Super Bee.
See below.@DeltaV does your part book have a number for power drums master cylinder?
Parts manual shows 2808577 for power drum brakes in 1970.
Normal and just the way I like it... gas pedal height...
Yep... if ACC put the pads in the correct spot in 1988 it would be !The gas pedal should be fully on the corner of the heel pad.
dot4Nice work Dave, what fluid did you use?
Oh we still have time for that.And no paint missing from inner fender, nice!
Any big reason you didn't want to go Dot5 and avoid the potential of removing paint?dot4
It was what I had at the house. 2 bottles.Any big reason you didn't want to go Dot5 and avoid the potential of removing paint?
Rain guards on quarter windows. Adjusted window,still need tweaking. Question on seal at front of door,what holds it up? DoExactly. I tried my best to fit my new ACC carpet with the pedal base where it's supposed to be, but there was no way in hell the carpet would fit properly that way unless I sheared 4 or 5 inches off the entire front edge of the carpet...and then it wouldn't have sat properly at all. So it's still an issue since 1988.Yep... if ACC put the pads in the correct spot in 1988 it would be !
installed the mirrors and drip rail seal today.Yes @DeltaV remote dr mirrorRain guards on quarter windows. Adjusted window,still need tweaking. Question on seal at front of door,what holds it up? Do
I use the last screw in drip rail or glue? Original had no hole.
