khryslerkid
- 5:46 PM
- Mar 10, 2010
- Hanover, Pennslyvania
What valve train are you useing? Cam, lifters, rockers.
I'll have to look into that. I don't remember. Everything's pretty stock, with a mild cam.What valve train are you useing? Cam, lifters, rockers.
It's my guess here, but if a cast crank had welding visible - it was more than likely internally balanced using the old weighted balancer and no torque convertor. If it was me I would pull the crank and give it to a shop to see what the imbalance is. You may have the parts to fix it, but in the wrong combination, or you might not have the right parts. You won't know until the crank tells you. So you can guess, or you can uncover the reality and address it. One thing is for sure - if the imbalance is making it shake starting at 2K, running it is a sure way to break it.
