bare metal preservative?
mmissile
5:15 AM
Motown
Looking to coat my cast-iron parts with something to deter rust, but natural looking. Don't want to paint or powder-coat.
Thanks.
You can check this out from Eastwood. I saw it before, but have not tried it...
  • Home
  • Calyx Manifold Coating 3 oz
Item #11171 Brand: Calyx
4.6 out of 5 rating. 4.6
(14)
Rub-in an instant, long-lasting,
cast-iron luster
Details
Rub-in an instant cast-iron luster with easy-to-use Manifold Dressing Your project vehicle's exhaust manifold will look like new after you rub it down with Calyx Manifold Dressing. It's easy to apply and long-lasting.
  • Rub-in with rag or toothbrush
  • No disassembly required
  • Enough for 8-10 typical V8 exhaust manifolds
More info...
About Calyx Manifold Coating 3 oz
Though it's not as durable as our paint on coatings, it is convenient and easy to apply because there's no disassembly required. Just remove loose rust and rub-in thoroughly. Non-toxic and water-soluble. A little goes a long way: one container treats 8-10 typical V8 exhaust manifolds. Made in USA.
Application
For the best results, manifold should be removed, abrasive-blasted, and wiped down with PRE Painting Prep (10041Z) before applying. If you wish to apply Calyx while the manifolds remain installed on the engine, use a wire brush to remove surface rust and dirt, then wipe down with PRE. Apply Calyx with a rag or toothbrush, and work it into the pores of the metal. For a buffed appearance, use a fingernail brush.
Contents
3-oz. container of Calyx Manifold Dressing, with instructions
Accessories
10041Z PRE Painting Prep, Aerosol
MSDS Sheet
Click Here for Material Safety Data Sheet
Customer Reviews
Reviews
Rating Snapshot
5★ stars
10
4★ stars
2
3★ stars
2
2★ stars
0
1★ stars
0
Average Customer Ratings
I'll be needing this for cast-iron suspension pieces. No heat involved.
Not sure if they still carry it, but Eastwood Co. used to sell a product they called Heavy-Duty Anti Rust #2712 for protecting bare metal. It's a spray on type product. Kind of like Cosmoline. Might be something to consider.
Check out Penetrol, it is linseed based and does not get hard or chip.
I have used "Everbrite" on my aluminum engine with no visual difference of the aluminum surface.
Mike
