Bighead440
- 11:43 AM
- Jun 18, 2017
- Milledgeville, Georgia
I mostly used the TRW high volume pumps in my bracket motors, I went with the Milodon dual external pump in my tube Arrow. The Milodon had different shaped rotors. Seems like the Melling has the same shape as the TRW. I agree with Doug, lots more things to consider in the oil system. Bearing clearance, rod side clearance mainly.
Melling definitely has MoPar style rounded gear lobes (at least all of the many that I have used). All TRW gears are not the spikey "Ford style" gears, I found out. I'm not trying to find the Holy Grail here, just hoping to get some benefit from the different gears. Somehow Milodon felt it was an advantage for their high-end pump, and I wanted to know why. To know for sure, I'd just have to try these gears myself and see, back-to-back on a known-quantity (hot idle/revving oil pressure, etc.) engine, compared to a standard M-63 or M-63HV. I wouldn't forsake my favorite HV unless things remained constant with the TRW gears and the standard M-63 was less.
