Best Hydraulic Lifters Suggestions
Testmanivy
10:50 PM
erie pennsylvania
Heard a lot of bad comments about the quality of today’s lifters.
69 RR 383 all stock
Looking for good/best replacements that work and not made in China.
tu
Not a fan of any of the Johnson lifters any more made this
last 20 years.
I love the old Johnson HP lifters from the last century.
Next best thing would be Mopar Performance from the
last century.
Those are the only Hydraulic we run in our Stock Eliminator race cars.
Find some pre-1995 stock lifters & have them re-faced....
All hogwash... I have used lifters from: Comp Cams, Howards Cams, Johnson-Hylift, EPWi (unknown origin), and more. I have used cams from: Lunati, Melling, Isky, Comp Cams, Howards Cams, maybe even a Schneider Cam, and others I can't remember. I have NEVER had a cam or lifter go bad with the exception of two of my own personal engines 30ish years ago that I had been talked into using Mobile 1 synthetic in on flat tappet cams. I attribute it all to proper assembly, proper lubricants, and attention to detail. I use Joe Gibbs Driven Assembly Grease on cams, lifters, valves, floating piston pins. I use Joe Gibbs Break-In oil on pistons & rings, and I use Sta-Lube Moly Assembly Lube on Bearings, lifter/rocker arm pushrod sockets. All of my engine builds get Joe Gibbs Break-In oil of the proper viscosity and instruct the customer on a proper break-in procedure with a final warning to only use either Joe Gibbs HR High Zinc oil or an Amsoil High Zinc product for flat tappet cams or a quality synthetic for roller cams. I have built engines for 3 or 4 members on these boards, one of which had 5 engines built. I have built diesel engines, race engines, stock engines, show engines, vintage engines, at least one Exotic engine (Rolls Royce S2), Industrial, Agricultural, single cylinder, Mercedes, BMW; too many to remember them all. On every engine I build, all surfaces are machined, all parts are replaced, proper assembly procedures and lubricants are used, attention to detail and above all else, cleanliness... There have been a few problems with bad parts, or hidden defects in blocks or heads that were resolved, but no cam or lifter failures.
No flat tappet cam/lifter failures? Really? You need to leave that cave you have been hiding in.....
