Best lube/grease for window lift mechanisms, gears, and tracks?
idrivemopar
10:46 AM
Colorado
So, getting ready to re-install my window mechanisms, and the serrvice manual says to use Lubriplate or equivalent, but there are at least 20 different kinds of Lubriplate, so what is best to use on the window lift plate slider, tracks, and gears?
I just used white lithium grease in a spray can, worked great for me.
I used the same Mobil synthetic that I use for just about everything else. It's hi-temp stuff so it won't melt all over the inside of your door. Spray can white lithium sounds like a good choice too.
White grease here. You have to consider if the temp gets really cold a thick sticky grease will tend to bind up.
all the window regs we install here in the shop get white lithium.many of the factory ones we get come pre lubed with it as well.
