Mstone68440RR
https://www.forbbodiesonly.com/moparforum/threads/68-rr-still-wont-start.144552/
Been having issues for some time now and became frustrated enough to give up and let the car sit for several months after many failed attempts at getting it running.
Above thread is a continuation of a previous thread and details all of the attempts to fix the problem. A few members suggested testing the coil pickup which ended up being the original cause of the car dying on the road and not starting. About a month ago I pulled my head out of my *** and was able to start the car finally. It idled great for 5-10 minutes so I shut it off. Excited to drive it again I started it up later the same day and adjusted the timing back to where it had been before.....no problems.
With plans to hit the local cruise night I got home from work the following day, started the car to warm it up, no problem. Shut it off, went inside, changed and then loaded a set of new wheels and tires in the trunk to have mounted and balanced. Started the car again and drove it out of the garage so I could air up the low rear tire. By the time I got back with the air hose the car died, figured it wasn't warmed up enough. Cranked it and no luck, tried again and again and acting like no spark????? Tested the coil pickup, still good. Tested the new coil and my meter suggested it may be bad so I bought a new one to try. No luck, took that one back and tried another coil, no luck. Pissed off I said F*&% it to the cruise and let it sit again.
About a week ago I tried yet again to get it ready for a car show coming up. Ended up testing the new MSD 6A using their websites tutorial and no spark from the coil, ok finally getting somewhere. I guess running a total of 15-20 minutes was just too much for this unit and it died?
Emailed MSD and they issued an RMA to return and replace the unit after explaining my dilemma.
So today the new MSD 6A arrived. I got home, installed it and sure enough the car fired right up! couldn't get it to idle and it was coughing and struggling to run smooth so I adjusted the timing a bit and tried again. Started and ran like **** still, so adjusted the timing a bit more. Started and ran like crap one more before dying.
One more adjustment and tried again, nothing.....................acting like no spark.....................AGAIN! Tested the new MSD and WTF no spark from the coil??????
Are these things so fragile these days? That is 2 new units and less than 20 minutes of run time! I have no idea what the next step is? I have no confidence in installing another MSD in the car if I can't even get the car running long enough to leave my driveway.
Is there anything I can test for to see if it is causing the MSD to fail so quickly? Something has to be wrong..........
Tempted to install a pertronix ignition and go that route.
Sorry for the long rant, just so frustrating to keep falling short of getting this thing on the road.
Mark
Mark
