Stoney
- 2:55 PM
- Jul 20, 2017
Their is a reason the manufacture's put only dot 3,4 or 5 only on their products. That being said dot 3 is not synthetic. Dot 4 and 5 is. Besides dot 3 attracting moisture, the main benefits of dot 4 and 5 is they have a higher boiling point with dot 5 being higher. If you are installing all new brake components in your brake system including the brake lines I have upgraded to dot 5 with no problems. Do not mix dot 3 dot with 4 or 5. If you are not racing this car you really do not have to upgrade your brake fluid. Just change it every 5 years. The newer fluids can react with the older seals as they were never intended to be used with the newer fluids. Kind of the new gas we have to deal with. Good luckI am upgrading to front discs on my '63 build, so all new across the board, along with 11x2-1/2" in the rear. Since our cars are stored more, than driven, due to our short seasons here, what type of brake fluid is the best choice, for resisting moisture break down, resulting in failure ? All input appreciated, Thanks...
