Brake peddle height
68bigblock
6:11 AM
alberta canada
hi all, is. there a way to adjust peddle height, i changed the booster and now the peddle sits low
I ran into a similar problem. If you separate the booster from the master cylinder, there is push rod. There is an adjusting nut on the end of the shaft that can increase or decrease the movement. I would try this first.
ok i will try setting it again, Is it supposed to be set with a slight clearance to the spool in the master cyl.?
What I did was make a tool from a small wooden rod or even a pencil. I marked the rod as to how far it would go into the master cylinder and just come in contact with the master cylinder plunger. If you set it too far in, then it will start to compress the master cylinder and lose pressure.
