Bulkhead Wire Connector - 63 Plymouth
Ron H
2:48 PM
WI
Been searching for the fire wall bulkhead block as the one on my Fury has a separated terminal fire hot wire that's loose in the block. Was considering trying to solder this connector so it is secure in the block but not sure how that would work. I haven't found these available so asking if anyone has a lead on one or advice for repairing it.
You might try Kramer Automotive for a used one.
724-285-5566
Try Evans wiring harness
I will give these places a call. Thanks for your advice.
I have the one off my 65 thats not being used. Want it? Can snap a couple of pictures of it to verify if it is the same. PM me with your telly number and will send them if you are interested.
I thought I remember hearing about a problem like this and it was resolved by drilling all the way through the connector and then soldering a piece of same gauge wire and passing it through the hole to the interior and soldering there also. Slide heat shrink onto the wire before soldering then shrink it down after sliding into place. Just an alternative.
Ckessel - your mail box is full yes would like to connect on the bulkhead block.
