rumblefish360
Agreed!
Which 268 do you have?I have the 268 now my engine builder told me it's a small cam
268 hWhich 268 do you have?
The 268H or the XE268?
THese are good ones. Edelbrock Performer-Link True Roller Timing Chain Set See the 3 slots in the crank gear. (small gear) That's what you need. If you want to read up on the subject, Karl wrote this and it contains a lot of good info. How to Rebuild a Small Block Part 10A (Optional): Timing Chain OptionsI got a hold on a engine. Builder I used on my old 69 Dart ,he is going to degree the camshaft,he told me to get a 3 key way sprocket,don't want to sound like a dummy on the phone when ordering,so could someone help what's good out there.thanks again.Don.
I hit that link it says v6THese are good ones. Edelbrock Performer-Link True Roller Timing Chain Set See the 3 slots in the crank gear. (small gear) That's what you need. If you want to read up on the subject, Karl wrote this and it contains a lot of good info. How to Rebuild a Small Block Part 10A (Optional): Timing Chain Options
Nice!My 73 Challenger has a Crane hyd roller very simalar to post #9. 360, 9.0-1, ported factory heads with 2.02, TTI headers and exhaust system, LD340 intake, 650 Holly DP. 4 speed 2.47 1st, stock springs and shocks, pinion snuber. With 3.55 and 275 drag radial it's been 12.70s@109. With a 4.30 and slicks it's been 12.50s@110. Always thru full exhaust with the airfilter in place. Runs on 87 octane. Though when raced we run 93 just in case. 99% street car. drives great. even managed 18mpg using a 2.76 gear on a long trip.
Look closer.I hit that link it says v6
Thank you ,how hard is it to degree the engine in the car.Look closer. View attachment 1600397
A big degree wheel may be an issue.Thank you ,how hard is it to degree the engine in the car.
Yup I just visualize in my head that wheel will hit the k frame.A big degree wheel may be an issue.
It happens a lot, you can go back and hit REMOVE.Sorry bad fingers
Gosh, so he fat fingered it, errors happen.Bubeis????
What’s next? A hand written two page apology and how it’s bad to hurt others feelings by mistake?
