pedal2themetal
HI,
Now that its all back together .. NOt starting... I've double check Plug wiring, distributor firing order, it has spark. a couple of back fires thru the carb. I think I did flood it putting gas in to the carb via cup into vents.. I have the plugs out drying it out..I did smell gas when I pulled a couple of plugs
If I (I'm afraid of this part) put the cam gear in 180* out?? Is there an easy fix
with out removing the front end again?? like just moving the distributor 180*?? to fix this Please.....
What would I look for in the valve train for TDC ?? exhaust valve just starting to open????
