- 8:20 AM
- Aug 5, 2011
- Lisle, HELLinois!
I agree with everything you guys are saying! Sounds like the Lisle 18000 isn't
the right tool for the job! Your mandrel has to be the size of the finished bore
for it to work right. (with no re-work) The cone on the installer keeps the bores
straight. If one is in a little crooked that's a problem. If you put a burr on one,
that's a problem, and if the cam has a bend in it out-of-the-box, that's a big
problem. Giving it a "Wahck" with a dead blow on the high spot will usually
do the trick. Expandable mandrels are for the birds. They sacrifice accuracy for
size compatibility. Glad Cranky made the comment about checking the runout
right out-of-the-box. If you think you have a hi spot and scrape it and then
find out it's a bent bumpstick, you're out another set of bearings and your time.
