How risky is removing and reinstalling a cam bearing if oil hole isn’t aligned?
I know it’s not the best practice…but let’s say I misaligned the oil hole on a cam bearing. How risky is pressing it back out and reinstalling it in the same bore?
Possible that it’s fine, or high risk for a spun bearing? It seemed to fit tight, just not as tight as the first install.
This is for a lower buck cheap refresh I’m working on. Obviously I get that the “right thing” to do is remove and install a brand new one.
I’ve successfully done it using a real cam bearing installation tool. On some blocks you may need to enlongate the oil holes to get them to line up properly. Proceed with caution!
I don't know about the LS, but I have removed a new Big Block Mopar cam bearing that was not aligned correctly and re-installed it with no issues.
