Not sure what your stall out is, with my poor ignition wire connection car would not run unless leaving the key turned to the start mode. Common culprits are a bad ignition switch or ballast that checked good. Came upon the poor connection by chance more than skill - bumped the harness and presto car would start. Good luck - review instructions for how to take out the bezel and cluster for your car. For mine, I put a towel and masking tape on the steering column to avoid marring it and the edges of the bezel. Stay gentle and patient...to avoid stressing wires/connections at least is the case with mine.
