99% sure its electrical and may be the bulkhead. Disconnect it and spray it with contact cleaner. Check for corrosion on the contacts. finish with dielectric grease and reconnect.
other things to check would be low voltage at the ballast resistor and coil positive. Looking for around 7-9v at coil. Also bad grounds or loose wires on the ballast resistor or coil. Wildcard would be bad ground on neutral safety switch wiring if you have a 727. A partially melted NSS wire flapping around a hot header collector could cause problems.
the times this has happened to me it has been a loose connection on an ignition wire. It is the worst feeling i can relate that much, especially in traffic.
