Car Sputters Out
holanae
6:01 AM
Houston
Cruizing it never happens, but if i get hard on it, and let off, the ignition drops out. Atleast i think its the ignition. During its stumble, its not responsive to the throttle. Take it to neutral and start it back up. It might run a little rough at first but continues on perfectly fine. It only happens once on my cruises around town. Get on it again and it does fine afterwards.
This started after a test and tune session on the dyno. It started burning up mopar ignition modules before i stepped up to a MSD ignition box. When it would stumble is when i would fry an ignition module. Luckily, the MSD box is alot more rugged and handle it. Car had no issues prior to the dyno visit. All wiring is new from full restoration 2 years ago. Running a fairly new Firecore distributor (Dec.) and new coil. Power and ground for the ignition module is hooked directly to the battery. Igntion on wire comes from the ignition run and start wires. Any ideas?
Wiring looks good. Pulled the dist. cap and everything looks good. Magnetic pickup is reading the correct ohms. Could it be alternator or voltage regulator related?
Were running a high flow mechanical pump. Its also brand new. Swapped it out on the dyno when the old pump was dropping down to 2 psi through the power band. Replaced the pump and pressure held steady at 6 or 7 psi. Cant remember exactly
Yesterday i goosed it. Not enough to spin the tires but more of playing around and it died. Get home, and stomped on it from a stop, let off after it gained traction and the car was running fine.
Float level? Debris in bottom of float bowl moving around?
Sight glass shows good levels. New carb installed before dyno run.
How about timing? Could that throw it off. Timing is set at 25 at idle, and all in at 2400rpms at 38.
Sea level. What’s the ambient temperature. Ethanol content of gas? Coolant temp when this happens.
It has happened at various temps. Running 93 pump gas .
Checked voltage at battery when running. Its at 15.3 volts at temp. Give gas then ket off and it went down to 14 volts. Gave it alot of gas and let off a few times. One time it dropped to 13vdc and the engine responded by running a little rough. Hit the gas and engine cleaned up and went back to 15 volts.
New carb before the dyno and problems started on the dyno. I would start at the carb.
Sounds like it's too rich and fouling the plugs to me.
Just did a twenty plus mile cruise without issue. Got on it plenty of times. I originally was thinking ignition because i never found what was fouling out the oe ignition modules before i swapped to msd. Something so remote and unpredictable like this, now i am thinking stuck float. Like i said, car ran fine before dyno. Only thing he messed with was the distributor and the jetting.
