Car stalls at idle after twenty minutes or so.
Nick ciavarino
11:33 AM
New castle pa
64 sportfury street wedge alt good battery holds charge only thing is battery dies and car will not start no dome lights dead what else could it be thanks nfcia53.
I think you should re-test the battery & alternator. Besides that, maybe replace the voltage regulator. To test yourself that the batter & charging system is good, put a meter on the two battery terminals. It should read just about 12V when the engine is off & a little over 14V when the engine is running....and clean the battery terminals while you're at it. GOOD LUCK
Sounds like your running on battery voltage
alone,that's why it dies.?
Like above, check charging system thoroughly.
No dome light? Check the bulkhead connections, ammeter connections. I had a new-bad negative cable do that once.
Thanks.
