So my motor will run pretty good with a Holley 650 carb I have. Crazy it runs fine for a while then wants to act up. Was running too rich with primary jets at 80 and changed back to 76 jets. Was getting spark knock at cruz speed about 65 MPH. This thing has been going from one end to another. Have tired fuel boost. Now running a mix of 93 non ethanol about two gallons added to a tank of 93 ethanol base fuel. Talked to my motor builder and he told me I need a larger CFM carb like a 750 for my motor. Like stated 383 with 9.8 to 1 compression. Half dome pistons. Stock heads and stock manifolds. Running the Orange box. Wonder if that is not my problem. About 3000 miles on the motor since rebuilding it. After changing the jets back to 76's at about 65 hit the gas and kicked in the four barrel it popped a couple of times then took off. Guess I have something wrong. Any input will be greatly appreciated. Blue.
