Carb Spacer Tech
68 Sport Satellite
6:56 PM
San Jose, CA
I currently run an open 1/2" phenolic carb spacer with my dual plane Edelbrock Performer RPM intake. I'd like to try a tapered 4 hole spacer and a divided spacer to compare performance at part throttle as well as mid and top end.
For the divided spacers, the only ones I'm seeing on Summit are these 2 by Edelbrock. Good choice? How do I know if I need the one with a single bolt hole in each corner vs the one with two bolt holes in each corner for my QF holley style carb?
Made in the USA
Edelbrock 0.5 Inch Carburetor Spacer 8722
Carburetor Spacer, Wood Fiber Laminate, .500 in. Thick, Divided Plenum, Square Bore, Each
Part Number: EDL-8722
4.78 out of 5 stars ( 18 )
In Stock (more than 10 available)
Estimated Ship Date: Today
$52.95
Add To Cart
Made in the USA
Edelbrock 0.5 Inch Carburetor Spacer 8725
Carburetor Spacer, Wood, 0.500 in. Thick, Divided-Wall, Square Bore, with 5/16 in.-18 x 2 1/4 in. Studs, Each
Part Number: EDL-8725
4.69 out of 5 stars ( 45 )
Those are just edelbrocks ,there’s plenty more from other manufacturers and at some crazy prices too.
My friend who services street rods (32 Fords with Chevy 350) swears by these
- Home - Home
while I am benefiting from the spacer being a heat shield, I'm also wanting a performance bump for throttle response, hence the tapered 4 hole and divided spacer inquiry.
