Carb tuning
Chad Witham
2:13 PM
Indiana
I attempted today to do some carb tuning, mostly idle mixture baseline stuff attempting to help my vacuum out, and make the idle quality a bit better. Nothing major just screw turning, well I screwed it up and now it has little vacuum and idles like crap. Anyone have a good baseline procedure so I can start over. It was running fine until I tinkered.
Well first off we dont know what carb you are talking about. Edelbrock, Holley etc etc. If its a carter/edelbrock I think seat all the way in then out 1.5 turns as a base on both. If its a holley
Edelbrock
Holley
Warm the motor up, one at a time back out an idle screw a bit. Slowly turn it in, when you hear a noticeable change in the idle back it off 1/2 turn. Work your way around the carb a few times.
First disconnect & plug the vacuum advance hose (if you use one).
Then, hook up a vacuum gauge to the manifold port (usually at the front of the carb) or directly to a fitting on the intake if you have one.
Engine fully warmed up, set your idle (800-900 rpms).
Then turn the idle mixture screws in or out to get the highest vacuum reading. You may have to re-adjust the base idle after that.
Don't forget to reinstall the vacuum advance hose.
Holley's are the easiest to setup.
So since we’re talking about vacuum is 10 as good as I should expect with a bigger cam?
How big is the cam? If it's in the 240@.050 range, 10 could be ok.
Make sure it has PLENTY of initial timing on it! 10* is NOT a lot.., that's stock 318 territory.
Baseline on a holley, lightly bottom the idle mix screws and back them out 1.25-1.5 turns. Keep all of them equal, whether 2 or 4 of them.
In general you want highest vacuum leanest point. With an auto, you usually have to fudge that a little to the rich side, screws out an extra 1/8 turn or so.
Cam is a crower 31204 grind hydraulic flat tappet, it's .474/.480 218/227 @.050 on a 108 LSA.
