Carburetor Recommendation
496 polara
6:10 PM
North Carolina
Is there a carb builder someone can recommend for a carb with the fuel curve already set? Tested on a running engine for a/f ratio at idle,cruise,WOT? I know jetting may change but not excessively lean or rich on any part of the fuel curve should be doable?
Something around 950 cfm on a 4150.
Or someone reputable to send one of mine to.
I've sold quite a few QF Q950' s that are most often dead on. That's part of what you get when you pay for it.
Edelbrock VRS. I have the 750 and ran awesome right out of the box
I was going to get one of those, but noticed it's 1/2" to 3/4" taller than most Holley 4150 carbs and I'm already at the limit for under hood clearance, so I ordered an Edelbrock AVS2 800 instead (not yet installed). My QF 735 SS works well, but I'm looking for crisper throttle response.
Aren't you in NASCAR country? Should be able to find someone around you.
