Carter AFB AVS Intake
1:45 PM
Indiana
Will a Carter Afb 4131s from a 66 383 bolt on and work on a 1969 hp intake manifold that housed an AVS originally? Wanting to build up an original looking 383 for my 66 Coronet. Not caring about numbers or original parts. I have a 69 intake and dont want to buy the AFB if it wont work.
I am pretty sure the 66 383 AFB had the narrow bolt pattern, so if that's the case, the 66 carb will not fit the 69 intake. That said, the narrow patten carbs can be drilled to fit the later intake. Early carbs usually had two of the wide pattern bolt holes drilled already.
