Carter fuel pump leaking
crossram 426
9:57 AM
Australia
Hi all, just noticed my fuel pump on the 440 is leaking out of the 2 small holes on the main body. It's squirting out both sides when the engine is running. What would cause this? cheers in advance. Matt
I believe that means the pump is bad. I suggest you install a new one before your car catches fire.
By the way, coloradodave was selling one of these pumps on here just a couple days ago. Don't know if it's still available, but his was very reasonable and Dave is a stand up dude.
Those pumps are notorious to develop leaks due to the usual cheap components and crappy pump gas......
As mopower stated keep a spare kit handy......I had a spare kit as well for my charger.....
Oh man, don't tell me that. I have one on mine also. :(
pump arrived an hour ago...swapped it out checked the oil...started her up and no more leaks.....very happy. Thanks for all the help fellas much appreciated. Matt
Once I put the Mancini kit in it, I didn't have any problems but I bought a spare just in case.....It is the typical cheap manufacturer internal items initially......
I thought I read somewhere on here that the kits Mancini is /was selling were not very good. Is this still an issue or is it safe to buy a kit to have on the shelf? Just curious.
My kit is still working fine for the past 4 years.......
Mancini kit is not for original Carter pumps based on picture. They show a 6 hole diaphragm which is similar to Ford/Chevy versions. Mopar Carter pumps are 8 hole. THere are other companies that sell a good kit for rebuild. I have done several for Hemi motors. Remember not all pumps are rebuildable, in fact originals for 383/440 were not. Different type.
There are a few companies that can rebuild original pumps........
Back to the topic of newer pumps...ski I believe it was the MR version....
Doesn't matter new or original, you need to know what you have. I have rebuild new carter pumps too. If Mancini has there own brand made by carter with 6 holes, which mimic the Chevy Ford versions it won't work on other Carter pumps using 8 holes with out modification.
The internals are all the same other then spring tension and obviously the lever arm.
But for an OEM motor you would have had a 8 screw Carter.
