If your asking about an 8.75 rear, then your answer is yes. Any center chunk / carrier assembly will interchange with another. There are 3 different casting numbers. The last three digits are 741, 742, and 489 numbered cases. They will have a different sized pinion gear. The axle splines should be the same.
The only problem you may run into is there are two different size u-joints. However they make an adapter u-joint that will go from the small one to the large one.
