Kimodc
I saw on YouTube yesterday someone was checking for exhaust leaks by adding pressure to his exhaust system by switching his vacuum hose on his shopvac to the exhaust outlet and then shoving the hose in the tailpipe. He then simply sprayed down all his exhaust joints with soapy water and looked for leaks, similar to checking for leaks in a tire. For a dual tailpipe situation, you stopper the other tailpipe. This looked like a ridiculously easy way to check for leaks without working around a hot exhaust system. Are there any dangers to your engine in doing this? I can see where a valve or two may be open into the heads at any given rotation of the engine, but it is not like there is much air flow that will be carrying particles, more just air condensing and building to pressure. I don’t want to risk damaging my engine, but it sure looks like an easy way to check for leaks…….am I missing something?….. What are your thoughts?
