Clutch
TOMRR
11:01 PM
MASS.
I have the motor out of my 69RR and at this time would like to replace clutch, pressure plate and throw out bearing. I currently using a 12 inch McLeod set up and seem to be working well. I have a few miles on this clutch and seems to be fine , But feel that seeing that motor is out might as well put in new !! Any outer Clutch Brands Recommendations would be helpful.
Thanks Tom C.
I've never run a McLeod, but I have run stock, Zoom, Hays & now Centerforce diaphragm style. I am VERY impressed with the Centerforce dual-friction. I did have to remove the over-center spring (short, big fat one), but that was pretty easy, though a tight fit to get it out.
I'm running McLeod in two cars and I think they are top notch. Hard to beat one.
I can't imagine a clutch better than a Centerforce dual friction. I suggest you study up on them, and they will tell you what makes their technology work so well. The ease of pedal is just amazing..................MO
Thanks Tom C.
Clutch Pkg
This is what I ended up getting from Passion Performance in PA. 3-FINGER TYPE PRESSURE PLATE
McLeod Clutch Package 12" 23 Spline (Use With 143 Tooth Flywheel) Includes Disc, Pressure Plate, Throwout Bearing and Pressure Plate Bolts
Product Details...
