WTB Correct 4 groove (AC) lower pulley 67 - 68 GTX
AR67GTX
9:55 PM
Arkansas
Feedback: 15 / 0 / 0
My current pulley has a bit of wobble and I’m looking for a no damage replacement. Current pulley has two large pulleys for AC in rear. Slightly smaller pulley for P/S next. And slightly larger pulley up front (about same dia as AC pulleys) for driving the water pump. There is a slight gap between AC and P/S pulley. Not sure if it’s a correct pulley or not. Car is a 67 GTX with 68 motor.
thanks
thanks
your inbox is full
I have 2 factory pulley's like your looking for.
Starting by the timing cover 2 large diameter grooves the a smaller one and then a bigger one.
The pulley's look the same from the front but the one on the left has some thicker metal
on the back side and is heavier. I thought you would be able to match your original
with one of these. They both have been bead blasted and primed!
If interested start a conversation with me.
Thanks! John
thanks
I have a 4 groove pulley # 3614382
