Dominic
Hey guys, I was wondering if you think these valve springs for a 440 build would work for my setup... The heads I have are aluminum Trick Flow 240 (TFS-61617802-C00) with valve spring specs:
1.550" O.D. dual spring with damper (TFS-16094) 138 lbs. @ 1.950" installed height
430 lbs. @ 1.250" open
420 lbs. per inch rate
.680" maximum lift
I want to use a hydraulic roller cam (Comp Xtreme Energy 23-710-9), that will have about .574/.570 valve lift (after 1.6 roller rocker arms). Is this too much spring pressure for this setup? Would a valve spring change be necessary? Thanks
Other specs: 440 is .030 over, CR ~10.5:1, link to cam specs
.680" maximum lift
