SOLD DANA 60 4 SPEED DRIVE SHAFT
ROB SHARON
11:32 PM
Washington, Michigan
Feedback: +55 / =1 / -1
1970 orginal 4 speed Dana Drive shaft. Asking $475.00
What is the difference between the Dana and the moper 8 3/4 rear end with the 4spds length?
The Plymouths Drive shafts are 50.39 inches
I am not a expert but want to understand...
Dana driveshafts 1966 thru 1971 are the same size for all B bodies?
8 3/4 driveshafts 1966 thru 1971 are the same size for all B bodies?
so why is does your drive shaft have different measurements?
Thank you sir:
Thank you sir:
Dodges have a 1" longer driveshhaft and Dana's use a shorter driveshaft than a 8.75.
The front leaf spring mounting brackets are 1 inch longer on the Dodge B body cars,117 inch wheel base,verses the Plymouth B body cars,which have a 116 inch wheel base.
Difference between a Dana 60 and a 8 3/4 is 1.14".
Hello sir.... is that consistent with all 1966-71
Being new to Mopars are we measuring the shaft with out the U joints?
Thank you....
