Dash emblem removal help need
rog_allen
6:36 PM
minnesota
71 sat air cond...
1...does the dash have to come apart
2.. Are they a press fit or some kind of clip or nut on the back ?
3... Is it attached to the paneling part ?
4..does the paneling part have to come off dash to change emblem ?
Thanks
Remove the glove box
With a stubby Phillips reach up behind the woodgrain insert and remove the 5 screws.
Remove insert.
You'll see that the emblem has 3 studs. Carefully push on the studs removing the emblem from the back.
being an a/c car you might have the remove the ash tray also.
that sounds easy enough.... Thank you
PS... IF IT IS JUST PRESSED IN ..I WONDER IF A GUY COULD JUST SLIDE A PUDDY KNIFE UNDER THE OLD ONE AND LIFT IT UP THEN PRESS THE NEW ENBLEM IN ?
