Dash lights...
anmracing
6:43 AM
Arizona
I did a search with no results soooooo, anyone know where I can get the light that pops into the tach of a 1969 RR? I have the tach but it didn't have the light. I am assuming the same light was used for the clock but don't know for sure. I'm going to call the place that I got the tach from and see if they have it because I didn't see it on their website...
It is a metal hole that is not like the rest of the dash lights so I guess it has a wire coming off of the light for the ground.... Maybe???? Anywho, I need it and don't know where to go, I googled it too and I get nothing. Any help from the FBBO peeps????
Appreciate ya'!!!!
The clock and the tic-tock-tac used the same diameter pop-in lights as the rest of the dash in the ralley dash at least. The ground for these lights were provided by the entire dash assembly. If you have an aftermarket tach sounds like you have the right idea calling the manufacturer. Sounds like you might have to custom make a solution.
