Dash Pad Replace, Dash Shell In or Out of Car?
LSS&B
5:18 AM
Aylett, VA
OK, I have to remove the windshield on my 1966 Coronet 2-Door Sedan. I also want to replace the dash pad. I have a new dash pad on order from Classic Industries.
Since I will have the windshield out, is it easier to replace the dash pad with the dash shell out of the car? Or should I leave the dash shell installed, pull the front seat, gauge cluster, and glove box and do the repair from below?
Thanks!
I would just leave it together and replace the pad. It's not that bad.
Unless you've got another thing to fix or paint at the same time.
The windshield is out, so just remove the bolts at the lower windshield dash attachment points and loosen the bolts at the kick panels, then just tilt the dash toward the interior. It will rest on the column. The pal nuts can then easily be removed.
Gonna depend A LOT of how flexible you are. Ive done it in the past , when I was much younger
It can be done with dash in. But its A LOT easier with the frame out.
or maybe like mentioned, just roll it in back
I'm in the over 60 club. Flexibility is lacking for me. With this cold weather, flexibility is zero. When it warms a little, I'll probably rock the dash shell toward the steering column, reach through at the front window, and remove the speed nuts.
Good call, over 60 here too. If you want to try it with the dash in place, I recommend pulling the front seat so you have plenty of room to roll your tired old *** around under there. :lol:
If your dash pad is the same as 66 Satellite don't think you need to remove windshield unless you have A/C. Changed mine. Remove front seat or seats, makes it a lay down job,4 or 8 bolts.
Not to highjack the thread, but it got me thinking (actually a guy at work suggested) that there are (now) decent "snap on" dashpad covers. Not sure if it's ever been covered here....he's a pretty picky guy and hs several classic muscle cars. What is the group's thoughts or experiences? Is this blastphemy? Thanks in advance, PK
I've seen the plastic glue-on covers. Plastic looks like cheap junk compared to vinyl. My opinion is spend the $ and do it right.
Installed: column on seat, dash resting on column.
OER makes good quality pad. Classic Industries rocks! $457 with ship after I got an FBBO discount.
Doing it that way is easier, I was not removing the windshield, so I had to pull my dash apart.
