disc brake conversion
jcolville89
8:40 AM
louisville ky
i have a 69 road runner and i want to put disc brakes on the front what are some of the years i can get spindals off of to make work would like the most recent years i can get
Do some searching on this sight. This has been covered multiple times and there are lots of useful posts on this issue.
I could not find all parts so I went w/ the MasterPower brake set up. Came as a kit.
Damn, MOPAR parts are getting harder to find!
Good luck!
disc brakes
okay thanks i was wondering tho if any 1980 car spindals would fit tho or if i had to stick to the 72 73 cars there just a little harder to find in junk yards
The 1980 spindles work great. There's only like 3/8 of a inch difference from the 73-76 a-body spindles and the taller spindle which the 1980 had. I used both and I couldn't tell any difference.
73+ Bbody, F, J, M & R spindles are supposidly the same and can be used. As stated the geometry is a little different and some resources I found, state to the better over A & E spindles. There many many people who have used and continue to use them without issues. The last set I found and have are from an 82 New yorker 5th avenue and can post pictures here if you need
Yup, and much as I love old Rick at Mopar Action, he's mistaken about the bump steer thing with the later spindles. It's just not true. Been debunked a lot. Other than that, that swap article is awesome.
The biggest problem I have with the E-burg article is finding all five cars to get individual parts from, some of them pretty difficult.
Why not just use all the parts form the same car?
LKQ charges $75 for the spindle, rotor, and caliper assy from both sides.
The prop valve works too, but you'l have to plumb it with custom bent lines.
Plus $50 for a rockauto m/c and another $20 for the lines and fittings (and maybe $20-30 more if you don't have a flare tool and bender)
Under $200
If you can't find one that looks like it's been recently driven, you can always trade in the calipers and rotors for reman/new, at what, $50-60 per side?
I've seen several 5th Ave's at LKQ with new rotors and pads!
if your spindles are good,i like the adapter plates from scarebird on ebay.adapts newer calipers and rotors to your spindle.
i just bought a whole set up from a guy this past weekend at the nats. He uses fifth ave spindles and the whole kit was $420. New backing plates, rotors, bearings and seals, and hoses. He said to just use the stock metering block and change out the master to a stock front disc/drum. Said he hasn't had any problems with this set up.
I stopped by "The Right Stuff" tent and spoke with those guys and they said they do use the a body spindles with their kits, but also have u use the stock metering valve in conjunction with an adjustable proportioning valve for the rears.
If anyone wants this guys info just pm me, he also does 46-61 disc brake conversions as well.
most of the factory blocks are just diverter blocks and not metering blocks.when i convert i always install an adjustable prop vale in the rear line.otherwise your back shoes will be stopping with a bit too much presure when you switch masters for the front discs.
The "Texas" valve in F/M/J cars (and even in trucks as late as early 90's) is both a distribution and proportioning valve) No seperate adjustable valve necessary.
