Disc brakes for Polara??
wilbanks
11:18 AM
Carthage, MO
I have a 64 polara that I am wanting to convert to disc brakes. Does anyone know what brakes will work. I have been told I can use a body or F body spindles with my a arms. Any suggestions or info would be greatly appreciated.
Do a search on disk brakes. There are many posts on this subject.
Any kit that is for 62-70 b body or 70-74 e body will be a bolt on affair.
Great, thanx for that. I was hoping just to remove something used and transplant. Didnt want to spend all the dough in these hard times!!
You might be able to find late A body / B body stuff at pick N pull or a wrecking yard. The tall spindles work but getting aftermarket upper control arms is recommended to keep the ball joint from going into a bind during extreme travel conditions.
After doing my research,I purchased the SSBC basic kit.I like the fact the calipers are 4 piston,used my spindles and EVERYTHING I needed was in the box.Last coupla passes,my 3800 lb brick was 135 in the 1/4 without the white knuckles:munky2:
Pretty sure the previous owner of my 64 used brakes from a 70-73 Dart.
