DIY Oil Pan Baffle
Superbeemike
12:16 AM
Sparks, Nevada
I was playing around in the garage yesterday and was thinking about adding a baffle to the bottom of an oil pan to help control oil under hard g forces. Now, I know I can just run over to Summit and grab a $500 Milodon road racing pan but I love tinkering on stuff, and I wanted to try to make something. I started with some card stock and cut out something close, transferred it to some sheet metal and welded it in. I am not a great welder and know my mig welds aren't nice, and I should probably not own a welder, but it should hold. What are your thoughts, is this unnecessary or will it help? I think the oil will adequately drain to the bottom of the pan but thought I'd post this for thoughts.
Thats not bad at all. I was considering doing the same thing myself. I'm thinking, insert walls under the main caps to seperate the rod pairs. This should help to control windage some
That's not a bad idea. I read recently the new Corvette LT6 has something similar where it sections off each pair of rods for oil control.
Maybe incorporate a windage tray or at least horizontal baffles to control oil slosh on accel and decel. That may admittedly be over thinking it a bit.
Here is the pan I modified for the 360 Magnum I built. Added a "crank scraper" to the side of the pan. I used the Kevco pan for inspiration. Must check fit including dip stick before installing.
I have a template i made about 20 years ago. Take a look. all you do is print the pdf on a 8.5x11 paper, paste onto the metal , cut out and tack. Capture.JPG
