Nacho-RT74
- 12:20 PM
- Oct 8, 2012
- Valencia, España
I think I’m getting it now. Maybe there is some level of Asperger syndrome…
WHY don't you express yourself verbally rather than the little animated cartoon that is subject to various interpretations, ...... but free SPEACH is fundamental ......SAY what you mean, then misinterpretation goes away...... just my thought......expressed......
A typed response would be nonverbal.WHY don't you express yourself verbally rather than the little animated cartoon that is subject to various interpretations, ...... but free SPEACH is fundamental ......SAY what you mean, then misinterpretation goes away...... just my thought......expressed......
BOB RENTON
Semantics......is the word you are trying to say......I rest my point.......A typed response would be nonverbal.
I don’t think you better try to teach a class around here. The teenagers would make your life miserable.Semantics......is the word you are trying to say......I rest my point.......
BOB RENTON
Nice analogies with examples......providing one uses the same scale throughout. Especially when using the differential calculus functions. torque is a function of RPM......The general topic of Amps vs. Voltage brings up several analogous comparisons like Torque vs. RPM, Flow vs. Pressure, Force vs. Velocity, and such.
I found a decent article on this here: https://erode-sengunthar.ac.in/wp-content/uploads/2019/04/System-analogy.pdf
Simple answer is they are both important to produce work / power.
RPM isn't necessarily part of it; torque, or twist around an axis, can be applied with no motion at all. Such as when using a torque wrench at 0 rpm. or an electrical motor supplying force against a locked shaft.Nice analogies with examples......providing one uses the same scale throughout. Especially when using the differential calculus functions. torque is a function of RPM......
BOB RENTON
IFF (if and only if) they can get their faces and thumbs out of their phones long enough to create havoc......not for me...as I'm immune....and anything more than 30 seconds away from their phone, is considered a lifetime, as the world is passing them by.....what a hoot.....I don’t think you better try to teach a class around here. The teenagers would make your life miserable.
Very ture......RPM isn't necessarily part of it; torque, or twist around an axis, can be applied with no motion at all. Such as when using a torque wrench at 0 rpm. or an electrical motor supplying force against a locked shaft.
There's nothing like a good old fashioned 220-230 Volt shock to wake you up.For kiwigtx, getting zapped with 220 volts, is a lot more exciting than getting zapped with 120 volts.
I also tried a cracked plug wyre the other day.
I worked with a couple of guys who claimed the reasons for one or two errors was because they has Assbergers.....turns out they were just retards.Does having assburgers make you think you're the most knowledgeable person in the room? This may be a breakthrough!
Sounds like the childhood expression: "Mom loves me best"....or.....define EXACTLY what IS an assberger (or assburger) ???? Perhaps it meant to define what is a solid or semi solid fluid like or partial liquid fluid like material OR OBJECT that is sometimes found in one's initial layer of clothing, especially after over consuming a greasy, spicey repast. These conditions are sometimes accompanied with large quantities of methane gas (CH4) simultaneously, attributed to consuming of a legume type vegetable, aka beans. ......very dangerous flammable conditions.....that make themselves quietly, yet subtly introduced.......or......you define exactly what you meann......???....just my opinion of course......I worked with a couple of guys who claimed the reasons for one or two errors was because they has Assbergers.....turns out they were just retards.
These two mongs below.....
