DO I NEED A RETURN FUEL LINE?
redddd23
6:57 PM
CHICAGO IL
I put a new tank in my 68 charger and I am placing a red Holley electric pump with regulator. The tank has two lines coming out of it. I have a 502 stroker, running a single carb. Do I need to run a return line? Im not for sure where it would hook up to . The regulator that came with the pump has 0ne inlet and two outlets.
Nada. just set the regulator to 7 psi and drive the hell out of it. Your second line should be a vapor line.
Line on bottom is feed and the two facing are feed. You can just plug one of the ports with a 3/8 pipe plug and pipe tape. Use the other to feed carb. You can always pull the plug out to feed that 150 shot of nitrous you are planning.
Thanks!!
