Paul_G
- 10:43 PM
- Dec 24, 2013
- Surprise, Arizona
I am going to give this a shot. My 73 Charger needs new bushings and steering components, they are all half worn out. So whatever damage I do is temporary and a learning experience. Tires are crap too. Doing some internet research it doesn't look that hard.
I have a pair of home made slide plates, toe bars, two tape measures, a carpenters degree gauge, and a plan.
Ride height is already set were I want it. I plan to adjust each upper control arm for as much positive caster as they can get. Then set both wheels to .5* negative camber, set toe to 1/16" toe in, then drive the car. I expect it to pull to one side or the other. The side it pulls to will have the least amount of positive caster. That means I need to pull caster out of the opposite wheel making it less positive to match the other side. Then reset camber, reset toe and drive the car again. Trial and error till it stops pulling.
Anyone do this before?
