Does anyone use the Lokar Throttle/Kickdown cables?
1974DodgeCharger
6:16 PM
nc
I used to use them on my street rod. Nice pieces. Haven't tried them on a Mopar but can't imagine the quality would be any different.
I had both the throttle and tranny cable from Lokar on mine with no issues, pricy but real nice pieces.
I have been using this Lokar throttle cable on my 63 since 2006 with no trouble at all. Ron
I use both throttle and TF 727 kickdown on my 440, they both work great.
Guys, big shout out to Travis and the guys at Lokar. I recently swapped out a edelbrock carb for a Holley and in the process managed to break the Lokar kickdown cable clip (totally my fault). Going to the local speed shop here in Adelaide Australia, the guy said he had never seen one.....great. One email to Travis and no questions asked he has posted me the clip, catalogues, a couple of stickers for the back window all in a weather proof bag for nix, no charge!!
Today the weather here was terrible and given a normal package it may have turned up full of water, so hats of to the team at Lokar you have won a fan. and a brand ambassador right here.
I am running a 318 with an edelbrock performer intake and edelbrock performer carburetor. I used the lokar throttle cable bracket, throttle cable, and kickdown cables from them. Very high quality, easy to install, and easily adjusted.
Did you have to put a return spring down below to keep the arm forward why'll you pulled the cable tight?, just curious because I had to or the arm stayed about 3/4 of an inch back, after I put a spring on, shifts perfectly..
I know not a 360, but I Use them both on big block 400.. Work great! Wouldn't hesitate to do again if needed! Good luck!
