Don't be stupid....learn from my mistakes!
Kern Dog
Life is full of turns. Build your car to handle.
1:32 AM
Granite Bay CA
36 years in construction building houses, apartments, shopping centers, schools, all sorts of wood frame projects and I never had a serious injury.
Sure, there have been a few ladder falls, lots of splinters, I've smashed my fingers numerous times and had lots of cuts and scrapes but nothing even remotely life threatening. I've operated numerous power tools and never once had a serious injury. I've heard of guys cutting their hands with circular saws, knocking themselves out when operating a drill that gets stuck, causing the body of the drill to spin and smack them in the face. All of us in the trades have slipped off of a ladder or fell on our asses in the mud. That is part and parcel of the job....we are out there getting stuff done and no matter how safe you are, some things still happen.
For me, I had to retire to actually hurt myself.
Yesterday, I was doing something as simple as putting tools away while swapping a dishwasher here at home. I carried a few things including this angle grinder....
....when somehow I lost my grip on it, tried to grab it.....then must have pressed the trigger and cut my left bicep pretty deep. I had the wife rush me to the hospital. I was worried that I'd bleed out and die, I did not know how deep the cut was or how bad, I just wrapped a towel around it and called out to her and off we went. 6 1/2 hours later....
I was extremely lucky, I only cut tissue and somehow missed muscle, tendon and arteries. I am extremely grateful and have nobody to blame but myself, but....
This grinder....
Did originally come with a guard that would have prevented the cutting disc from touching me. Here is the way it looks when new:
The black steel guard would have hit my arm and probably prevented this. I looked a bit closer at the grinder today and while removing the guard never resulted in an injury while using the tool, it did when I tried to grab it from falling to the floor. Why is that?
Look at the way the trigger is positioned.
Almost all of the front face of it is trigger, to grab it, your fingers are likely to squeeze and start the wheel spinning. To add, the safety lock seen here...
Broke on this one and now it just lays like this:
This allows it to start just by pressing the black section. That is fine if and when you're ready for it to start which I always was until yesterday. I just wanted to warn others of this issue. I don't blame the manufacturer for ME removing the guard. I am completely responsible for that.
However....
It did not help that the trigger is so easy to engage. I got lazy and did not act with caution. This will not happen again.
Be aware of the risks when using these power tools.
Good thing you’re ok…that’s a big gash. I have a scar on my finger where my hand slid down a grinder and into the cutting wheel (where the guard was supposed to be). I was finishing up a job and making a few last passes to smooth burrs when my glove slipped and viola I had a divot taken out of my finger. Not nearly as big of a cut and the heat from the disk cauterized it, no blood.
Glad it missed the muscle and did not need surgery ect.
Thank you for the heads up most all of us should see.
I would guess that many of us have removed that guard.
My brother had one locked in the on position while under a car that he dropped and got nicked a couple times .
Glad your ok Kern.
Whew, that was a lucky escape. I am glad to hear you are ok and have no major damage. Kudos to you for high lighting here what happened and analysing your mistake. Having said that, I am sure that 90% of people (me included) take the guard off to get better access.
Imagine if you had bled out, we would never know how your engine build would conclude, and that would be a disaster. :poke:
Been there, done that, and got a t-shirt. Same here, nothing serious in all the years on the job, till I retired. They put that finger back on. You're home safe and sound, that's all that matters!
Thanks for the safety reminder complete with a real world example. Glad it wasn’t worse and hope it heals up nicely.
My wife would have been "YOUR FINE" can i use the dishwasher now!
I've got lots of white tattoos from grinders gone wild.Usually caused by a 6" wheel in a 4"grinder, not a lot of handle to hang onto when it grabs the particle shielding rag becoming a 120V wolverine!
the tool of death!...... my most used tool in the shop
you gotta respect that thing......... it'll bite
I'm always haphazardly sticking it where it doesn't belong........ never lost an arm though, Geeezus
glad your ok for the most part, please be careful
the safety being broke on the trigger makes that thing a loaded gun, almost
Glad things weren't worse than they were! I've done so many things that prompted (or nearly prompted) trips to the ER I was just now remembering them all. Worst one wasn't even mine. My wife's brother was making some shelving to save a few dollars, cutting wood with a circular saw when it kicked back toward him. Before the cover could snap back over the blade he cut two fingers off and a third was hanging by the skin. They were only able to find one of the lost fingers before heading to the hospital so I had to go into his garage to find the other. Turns out it was all the way to the back underneath a shelf across the garage. If it ever happens to anyone here, put ice in a Tupperware bowl, towel on top of the ice to keep the digit(s) dry on top of towel, then put the top on and proceed to hospital.
This grinder....
However....
You are lucky it didn't do more damage. It's good that the disc didn't break apart and come buzzing through your jeans in the zipper area. :mob: :mob:
