Door interchange
tomlin
12:48 AM
Cantrall,Ill
This is kind of a follow up to my earlier question. Do any other B body doors interchange with the 66 Charger? The GTX and Coronet look similar if not the same but I am not sure? This is my first early Mopar so please forgive my ignorance. I am weighing options on replacing the drivers door. It has been roughed up pretty bad plus it has some pin hole rust in the corners that will need to be cut out. It may be easier to locate a door or door skin then to fix what I have. I did see a door skin for a Coronet/ GTX on ebay. It was pretty pricy with the shipping. It is not that I CANT fix it what I have. I have fixed much worse for other folks but I would like to get this thing right.
A 66 coronet 2 dr hardtop door will fit your 66 charger. but it will not have the trim clip holes on the upper body line.
