I think the standard cable supplied in a new shifter is 5 feet. Hurst also sells different length cables individually because you may need one longer or shorter depending on your application. In your case, if the present cable length is such that it lays on the exhaust pipe and you can't find an alternative route, then you will want to consider a different lenght to clear any hazards (heat, binding etc.).
Hurst makes several model ratchet shifters and the cables are different depending on the model. For instance, the Promatic and V-matic are different from the Autostick, Quarter-stick and Pistol Grip models. The same is true with the B&M ratchet models which also fit the Hurst shifters.
Just remember -
1. Check your cable first. You are trying to determine if the cable is the cause of your shifting issue.
2. If the cable is damaged, determine if the routing or length was a factor in it's failure.
3. Before you order, know what model shifter you have. I would suggest ordering by phone so you can ask questions and make sure you are getting the right part.
I have found that the addition of a thermal sleeve on the cable can work effectively. It is not a cure all and still MUST clear all heat sources but it does reflect heat well.
