Edelbrock tm-7 and hood clearance
Travis_216
6:14 PM
Newfoundland
I have a edelbrock TM-7 here I had kicking around. I was wondering if anybody knows if it will fit with my 440 and a bulge hood? Just wanted to switch it up from the edelbrock performer. Also any idea what air cleaner I'd have to run with this intake manifold as well?
I've ran the TM-7 on a 68 Roadrunner with the stock air cleaner and on a 63 Dodge with no problems, they really aren't as tall as you think.
I've got a TM-6 on my 383. I don't think there is much difference in the two except engine. Mine is on a 69 Charger with a regular hood and fits fine. Here's what I have currently. I did switch out air cleaners from a K&N to the mopar.
The tm 7 will fit your 440.
I just thought and should add..I don't think however, there would be extra room for a carb spacer, at least in my application. If you have more space under your hood, a spacer would probably fit if you run one.
Thanks for the replies fellas, I appreciate it. I measured it up and it's actually not much bigger if it even is bigger than the performer.
