Nope, I don't run chokes on any of my old jalopies either.+1 for the no chokes crowd.
Oh wait, I guess I'm the only 1![]()
Guess you missed the spot where he said "if you run no ballast" (like an MSD unit). At that point that entire 12V feed is the same whether it's wiper, key run, key start, coil... etc.
yes i did thank you.Guess you missed the spot where he said "if you run no ballast" (like an MSD unit). At that point that entire 12V feed is the same whether it's wiper, key run, key start, coil... etc.
In the 90's here. Sweating like a pedo outside a primary school.+4 here today....![]()
I understand the springs function and how temperature makes it work. But what is the element that is creating the heat?For those that wanna know!
Holley electric choke has 12 ohms. Pulled out my cross ram with two Eddies on it and they're about 19. Took the T20 torque bit to the bad one that only reads 2 or 3 ohms and then drilled it apart. There is no resistance wire inside. Just a spring coil and a small disc that is isolated from the main plate, that the bimetalic is mounted to, by thermal paste to add some resistance. I guess the assembler didn't use enough and it shorted out. Now to figure out what it actually is and do some testing. #1 Son appears to have "borrowed" my electronics kit.
View attachment 1603844View attachment 1603845View attachment 1603846View attachment 1603847View attachment 1603849View attachment 1603850View attachment 1603851
The copper coil on the positive lead. It has zero resistance, then add the small disc and a thermal paste to give it 15 to 20 ohms resistance from ground and it starts heating up the aluminum disc and bimetalic spring. Best I can figure anyhow...I understand the springs function and how temperature makes it work. But what is the element that is creating the heat?
Weird. I always thought it was like circular element similar to the dash light dimming rheostat.The copper coil on the positive lead. It has zero resistance, then add the small disc and a thermal paste to give it 15 to 20 ohms resistance from ground and it starts heating up the aluminum disc and bimetalic spring. Best I can figure anyhow...
I'm sure it was heating up fast with 2 ohms!
I always use the wiper park feed.Don’t use the positive side of your coil for your electric choke
That’s what I see in your picture
I have used the wiper main feed on many 1406 edelbrock conversions when customer do not want to fiddle with the holleys no more. When the wipers quit working the fuse is blown and now you look for electric choke problems. Has always been simple. I thank the op for the info.I always use the wiper park feed.
I hooked mine to the alternatorThanks for posting this. Good to know.
Now if you have an electronic distributor, where you don’t have a ballast resistor, where do you connect the choke?![]()
I hope not to the output stud, as it's live all the time.I hooked mine to the alternator
