Brandy
Jack Stand Racer #6..and proud of it!
- 5:35 PM
- Oct 16, 2014
- Salisbury, Vermont
^^^^^where do I buy that part and what is it called?
Pinion? is that what the part that goes into the tail housing is called? I don't jave one that has the 7/8" output to connect to. I have downloaded manuals and a whole Audi world forum to ask questions. Plus I have a buddy nearby who was an Audi tech for 26 years.To me it looks like you need the correct pinion for the speedometer drive already inserted in the transmission. Then the new unit screws onto where the cable would normally go - and from there the cables carry the signal to the speedometer on the dash. Conversion or compatibility of that signal is the next task to figure out. Have you any factory manuals or information about the Audi speedo output signal?
Pinion is the drive gear inside the speedometer drive - the but with teeth - coloured plastic gear wheel.Pinion? is that what the part that goes into the tail housing is called?
Which is why I said the speedometer pinion drive needs to be the correct one - to give the best chance of calibrating the electric speedometer.That device has a fixed output frequency of 16,000 Pulses Per Mile.
I tried to do that late last year....but funds were needed elsewhere.Kiwi, perhaps we should just go to Ghosts’ house for a vacation and help him out?!
The adapters take different size ranges - just rotate to the 32-38 mark as shown.So the adapter I get will have like 32-38 on it and that needs to be at 6 o clock? I think my tires are 26" and the gears are 3.55. So 36 teeth and red color...
And make sure it's all clean as you fit it - and be sure that the O ring is seated correctly and not squashed. leaking tranny fluid up your speedo cable will get messy.The adapters take different size ranges - just rotate to the 32-38 mark as shown.![]()
