Engine Boss Location on a 383
Bigtime
4:16 PM
Virginia
Hello,
Can somebody post a CLEAR photo for me of the engine boss on a 383. I know it's located close to the distributor but I've forgotten where. Help an old-timer out, please.
Thanks!
It'll be outboard of the distributor on a flat surface right over the water pump port. Can't miss it.....
The distributor is above the letter F in this photo
The numbers are on the flat that's in the dead center of the pic
If a 383 gets decked the numbers may be gone. It's the same surface as the head.
Do I have to remove the dist. cap to see it? If it's a [ugh] 361 will there be a boss like the 383?
You shouldn't have to remove the distributer.Pad is below it. Just need something to do a little scraping. A 361, 383, 400 should be stamped in the same place.
Yes, same boss on all B blocks.
It is probably hard to see because of the alternator brackets and wiring, fuel line all are right on top of it.
Did the 361 engine have the same boss & stamping?
Sometimes a good shot of brake wash will let the numbers show up if the area is built up with grime....
Yup....to all of the above....
I believe that my alternator is in the way. The block is clean as a pin. The fender tag says it came with a 361, but it really runs STRONG.......it has a mild cam [no card], headman headers, Tarantula TM6 intake , 600 Eddy, and 906 heads, Pertronix module.....just FYI.
Sir, you are exactly right......the alternator is in the way, as well as the dist. cap. See info about the engine that I just posted, please. You guys are going to help me solve this yet!
Not saying a 383 can't be strong but if it's pumping out 1hp per cubic inch (which is pretty good), 17 more hp could make the difference in running strong or running strong :)
Now I see what you are looking for. What year is your car ?
Now I know 361's get a bad wrap but it is a big block and it sounds like everything needed to wake up the motor has been done to yours if it is indeed a 361.
In 1959 a 361 2bbl made 305hp with 400# torque
In 1960 a 361 2bbl made 295hp with 390# torque
They did start lowering compression after that so the numbers went down.
Ok, I moved the alternator, and here's what I found:
D 383
2 12
Should/are there any more #s? I figure that "D" isfor April and 383 [thank goodness] is 383 cu. in. What do the other numbers mean?
Please see my other post......I had to sandpaper the paint off [engine is clean.......D 383 and 2 12......can't figure out the 2 12?
