engine "shimmys" at idle with AC on
d9103365
12:26 PM
atlanta
I have a 77 cordoba 400/4BBL. Whenever I'm at idle and the AC is on, the engine seems to shimmy a bit as if its struggling. This goes away once i start moving. It also seems to heat up a bit during this time, and oil pressure goes down....all of this corrects itself once I get moving. I've seen this problem on some of my other mopars before...what is the cause?
sounds tune up related to me. Does your electric idle plunger work that is supposed to boost the engine RPM when you turn on the AC?
